Caltex Delo 400
Posted: Tue May 17, 2011 5:18 pm
by Mcnoogle
Hi Guys,
Obviously there have been numerous discussions and references to Caltex Delo 400.
I have read so many topics on this that I'm now rather confused.
My Paj as you all know is old, and not in showroom condition (doesn't even have a service history)
so Mitsu approval or not, I need to know finally,
1) Is it ok to use Delo 400 in my Petrol Engine.
2) Is it ok to overfill by 500ml.
Anton, cant remember if you have a petrol, if it is a petrol then I'll take that as my answer.
Thanks for your patience
Re: Caltex Delo 400
Posted: Tue May 17, 2011 5:25 pm
by JohanV
Hi Ned,
It should be fine as the one i am using and most others are Multi grade for Diesel and Petrol engines.
as for the overfill..... i did it and i havent had my low level oil light come on again
But thats my opinion
Re: Caltex Delo 400
Posted: Tue May 17, 2011 5:29 pm
by JohanV
as for Anton
tonton wrote:JohanV wrote:Which one do you use?
Delo 400 Multi grade or
Delo 400 Super Premium Diesel Oil ( I use this one)
Johan,
I use the same as you (Delo 400 Super Premium Diesel Oil - 15W40).
I actually thought that the 15W40 is a reference to multigrade
(MULTIGRADE = An oil that has a wide viscosity or thickness range.) - therefore my understanding is that the one you (and I) use is one of the Multigrade derivatives offered by Caltex.
Maybe the lubrication fundi's here can help us out.
Re: Caltex Delo 400
Posted: Tue May 17, 2011 7:10 pm
I have used it in
1995 jetta 1.8 petrol
1993 3.0 v6 pajero petrol
2001 3.2 Di-D pajero diesel
all of them were running beautiful and I overfilled all of them by 500ml.
Re: Caltex Delo 400
Posted: Tue May 17, 2011 7:17 pm
by ghost_traffic
Spoken to my mechanic about Delo400 and it's what I will be using for my next service.
Nico.
Re: Caltex Delo 400
Posted: Tue May 17, 2011 11:18 pm
by tonton
Mcnoogle wrote:...Anton, cant remember if you have a petrol, if it is a petrol then I'll take that as my answer.
Ned,
Mine is a 3.5 petrol, same as yours. I am using Delo400, and I over-filled by ±8mm on the dipstick.
The lifter noise returned (only when cold, and only for ± 5 - 10 sec) after 2000 km, but prior ir was noisy trough-out the day. The noise only subsided after I over-filled. Now and again one lifter is "hardkoppig" and continue to make noise, and that is sorted by the "revving protocol". That happens ± once in 2 weeks.
If this doesn't work, you will have to live with the noise till the next big job (cambelt), and then make a bigger job of it, and replace them.
I cannot guarentee that it is safe to overfill, but I have done it - knowing it is at own risk. I checked for bubbles on the dipstick, but never found any.
I say "goo for it" (at your own risk, of course!
