EGT where and what to buy
Posted: Wed Feb 27, 2013 11:22 am
by hogbeast
I want to install a EGT
1. where do I buy one?
2. which one do I buy
3. how do i install it
what temp should the gen 2 2.8T run at 750 degrees C?
thank you
Re: EGT where and what to buy
Posted: Wed Feb 27, 2013 2:43 pm
by hogbeast
Posted: Tue Mar 19, 2013 12:29 pm
by hend
Mgl avionics engine monitor. Put one in my 2.8 pajero. Very happy
Posted: Fri Mar 22, 2013 7:57 am
by MThompson
I've also been looking to fit an EGT. I haven't decided yet which one to buy and where to fit.
Also, I would rather like analogue than digital, but not sure which is the better option.
Seen some analog gauges at Autostyle......not to sure about quality and accuracy though.
Posted: Sun Mar 24, 2013 3:16 pm
by trekker1
I think Steve's Auto (tune up specialists) have then, maybe with multi point readings.
Posted: Wed Apr 03, 2013 12:18 pm
by hogbeast
is this a good place to install the egt
in the egr cover
Posted: Fri Apr 12, 2013 8:56 pm
by hend
Mgl avionics engine monitor E2. Search on this forum you will see more details.
Gauge on the left hand side
Posted: Sun Apr 14, 2013 9:23 am
by hogbeast
thanks for the info, that is what my research recommended. i actually removed the manifold yesterday and i am going to check the turbo aswell.
i bought the madman gauge and they say the gauge must not be i direct sunlight, i will have to fit it below the radio.
Posted: Mon Apr 22, 2013 7:50 pm
by hogbeast
egt installed this weekend, tested it today i must push very hard in 4th to get the temp to 600 degrees over 4000 rpm
i take it this is a good sign
