I bought a 2nd hand gen 3 lwb Pajero 3.2 Did GLS Extreme without the owners manual. Been waiting over a month now for Mitsubishi to provide me with one. Were can I find the correct jack points on the vehicle?
Jaco
Do you refer to the normal jacking points as used by the standard original jack? If so, the points are basically underneath the suspension arms of each wheel. There is a nice flat surface on each of them when viewed from underneath, this is where the jack must go. If you don't lift it there the standard jack can not lift it high enough to remove the wheels.
If you are revering to High Lift jacking points, the answer is that the vehicle does not come standard with any fitted.
A friend of mine has a gen 3 shorty and it has hi lift points on the sides of his towbar. By the looks of it, it could work
Henk Bannink
Hi CATS
Thanks for the reply. I thought as much but wasn't sure. I was referring to the standard jack points.
I was contemplating the need and how to for the High Lift jack point.
Hi HBannink
Thanks, I thought as much. One of the guys at Safari Center also said they will be able to fit it on the side of the towbar arm but not for the front. Will have to change the bumper, which I do not have the money for now...
Hi HBannink
