I had to do some work at a panelbeater after some idiot reversed into my front fender. While it was there I also asked them to respray the front ARB bumper the same silver as the vehicle. I think it came out great and finish the vehicle of nicely. Unfortunately Snoopy now has a silver nose and not a black one anymore as always indicated in my signature.
BEFORE
AFTER
tonton
I like it!
So does "Little Cats" by the look of it...
Cats, does your car fit in the Garage with that roof rack?
PAJERO 3.2 LWB GEN 4 AUTO
Bostokkelos wrote:Cats, does your car fit in the Garage with that roof rack?
Yes it does, but only just!!
I must remove spade if fitted and I must also make sure my rear worklight is tilted down, otherwise it won't fit (I have the marks on my garage to proof!). The rack also came with a halfrail that bolts onto it if needed. This obviously needs to be removed as well and as a result I just use the rack without it most of the times.
Just remember that my Pajero has slightly oversize tyres as well as suspension lift as well, so a Std vehicle should fit easily.
I am a big fan of the Outback rack due to its low profile and relative quiet wind profile.
What have you done to your Pajero today?
I added an LED strip light to the original luggage compartment light. The stardard light was just too dim for my liking. The new LED strip turns on with the original light, whether by opening the door, or by the switch. Nifty! :)
Site Admin
superairborne wrote:I added an LED strip light to the original luggage compartment light. The stardard light was just too dim for my liking. The new LED strip turns on with the original light, whether by opening the door, or by the switch. Nifty! :)
Pictures please... I have been planning on doing this for a while
Whom ever is considering inside vehicle LED retro-fitting,
China Town,Ottery, has a vendor of very affordable conversion applications (even if the festoon fittings are a little too long - the car's globe's clips can be bent back wider to accommodate, with a stretch).
!! NB -Just make sure lights are checked / working, before you leave the vendor's shop.!! :twisted:
It comes as a rectangular/square block, buy to fit size correctly, with multiple LEDs on the block, off which, there runs the two power cables, to festoon-like "plug". The light is far superior to the original 5-8w, and now consumes a messily .75-1.5w MAX. :geek:
A huge difference to one's power consumption, so much so, that when camping, I've often left on for the remainder of the evening, until retiring to sleep. They lights are also at the optimum positions and can be manually switched off, with the car's lamp switch.
As I have a drawer system, I've subsequently fitted an aluminum strip light above where the drawers / fridge opens. The aluminum strip lights, with long extension leads are great to hang in the tent / rooftop tent (which I have), side awnings, or just to suspend in a tree, near to the braai area.
All these applications can be directly of indirectly used off an auxiliary battery pack, and, even with the fridge working of the same battery, the consumption is kept to a minimum. There are now even flood / spot lights available, to use if a huge amount of recreational / work area light, is required. :ugeek: :ugeek:
I'll post some pics in second half of June, when I return from my overseas trip.
Achille
looked under it to inspect and noticed ripped cv boot... and bad ball joints.. yay... not.
07 Mitsubishi Pajero Shorty - The bush basher
90 Mitsubishi Pajero Ute - the project
89 Mitsubishi Pajero Shorty - The rolling resto
89 Mitsubishi Pajero Exceed - The donor
I will take a photo tonight and try to upload it tomorrow! (I haven't uploaded pics before, so I hope it's not too difficult.
