I replaced the suspension lower arms (front) for my Gen2 pajero (V44W) but i have a feeling that the mechanic used a toyota hiace ones. please give me specs for right and left lower suspension arms.
Because of this, my tires are wearing out on the outer side. when turning i get an irritating squeaking noise. please help and save my tires.
thank you
Denis,
I am not so sure a Hi Ace lower control arms will fit on a series two. They will either be be thin or too narrow.
If they are too narrow they probably fitted washers to space them up and I am also not so sure about the bolts that fasten them to frame .Might also have some play and that will screw up your toe and camber.
you must look at the settings as that is quite a difficult job to do at home as those camber bolts are hidden in the frame and difficult to reach.
I will try and get the origanal lower control arms part numbers for you but you mst supply me year model please and description. I am speaking under correction as the lower controll arms is also supplied with the lower ball joints as well. I bought a new one for my Blister and the ball joint was part of it.
Maybe he installed the wrong ball joints and will cause may problems as these fit only that space in the control arm.
