Bosbok
Packing solution
Hi Guy's this is my solution to "THE SMALL " boot of the pajero
It use normal black storage box
it can take either 1x 160 l big jim box +70l black storage box + my toolbox and some more OR
it takes 2x 160 l big jim box (they fit like they where made for Pajero)
it also carry a 20l water tank (permanently)
The shelf can carry about 150kg
Here is some pics
jotto
Re: Packing solution
Nice one Bosbok
and no wasted spaces either :?
J
troos
'lo Bosbok
I like the concept of your water tank. How do you fit and setup the water tank? And how do you get water out of the tank?
familyman
Hi Bosbok.
Nice one.
A few questions.
1. Is this permanent?
2. Does it clip into the standard roll back points.
Cheers.
Bosbok
Hi, i am glad you like it
Firstly yes it is permanet and it bolts down on the rear (3rd) row of seats safty belt mounting piont and on the cargo points .
And as for the water tank it slides in from the top into a small bracket that keeps it from moving.
You fill it from the back window and, i have got a pipe with a tap on the tank so you can pour water easy with out having
to move the tank out of the car
Hope this helps
Bosbok wrote:Hi, i am glad you like it
Hope this helps
Where did you get the cargo barrier and how was this mounted?
Bosbok
Hi ,the cargo barrier is build out of 20 mm Aluminium Square tubing and CONNECT IT , with 1mm thick square (oogies draad ) pop riveted to the frame
At the moment its fix to the boards frame at the bottom and with thin steel extensions to the last row of panic handles bracket at the top
But before I put the split board in it use to mount on to cargo load brackets closes to the rear seats
Hope this helps
