Pajero Sport Suspension lift is done
The Sport's lift kit is in. I fitted Stofpad's bash plate and Gearbox plates a while ago. The rear of the car was 350mm higher than the front. It might be possible that the Bash plates did pull the nose down a bit...but very little. I fitted Stofpad's Alu spacers in front (45mm lift) and this 10mm conveyor belt rubber on top of my existing factory fitted rubber on the rear coils. This lifted it a little bit at the back.
Now: The rear and the front is level at the same height, so luckily the car doesn't stand nose-up, and the nose down stans is sorted.
Car looks great and feels solid!!!
Rear rubber spacer
Rear rubber spacer
Rear view
Rear view
PAJERO 3.2 LWB GEN 4 AUTO
Davidvan
Re: Pajero Sport Suspension lift is done
Looks good, very good!!!!! Did you take any pics of the spacers by Uys, would like to see what they look like for comparison.
David
macjohnw
Bos,
Do you still have the standard shocks and coils in?
David I will try and get it a pic for you.
Mac yes its the stock suspension and shocks.
adrianglock
Looks really great with that kind of ride height! But I think you should also consider having a new tire - I mean bigger one and a beefier fender.
ghost_traffic
Looking real good. Now you just have to get it dirty. ;)
Nico
