I have a 2006 LWB DiD GLX. I have had some questions on my mind for a while now, so here goes:
1. I bought my paj with 265/75R16 tyres. According to the tyre pressure sticker on the driver's door the tyres should actually be 265/70R16. What are the pros and cons of my larger tyres in respect to fuel consumption, lock-up clutch and tyre pressures?
2. From time to time the engine oil pressure light come on when the vehicle is idling. As soon as some the engine revs go up the light goes off. Is this normal? This only happens about once a month. The oil level on the dipstick is correct.
3.My tyres have been squeeling the last 2000km. The tread is is very good, but when I go around a corner the tyres are very noisy. I've had the wheel alignment re-adjusted but now it's even worse. The noise is more evident on smoother tar.
4. The transmission temperature light comes on for a split second now and then when the paj is idling . This usually happens in DRIVE at a red traffic light. It never happened until after I topped the transmission oil up about 2 months ago. The light never stays on, though.
Any answers would be great! Thanks in advance!
