First. The reason. I have rebuild two 3.5 motors already. The first about a year ago at a cost of R45K only to last little more than 3 months. I replaced crank, big ends, pistons,rings, water pump, oil pump, lifters, gaskets (set) , idlers. It sounded great but it did not last. And I did not punish it more than normal. The second motor I replaced big ends, rings, lifters, gaskets and idlers. It too is on its way out. It is consuming about 2L oil per 500Km.So I am faced with the choice of rebuilding both again or buy import 3.5's or to do the lex conversion. The cheapest is the conversion.
On this thread I will show how I did it. Perhaps this could be of some help for someone that is facing the same problem.
I read a lot of stuff on the net and asked questions and it started to appear as if the Lexus bell housing will fit on the Pajero auto box. Lucky for me I had a spare auto box in the shed. So off I went to buy a Lexus Motor and gearbox. I went to Engine Den in Pretoria and they hooked me up for R4950 for the complete motor and box. Next was the engine management. I decided on the Spitronics ECU because you can buy a kit with all parts needed to install it on the Lexus. I also decided to use the Spitronics TCU for gearbox control. The total for the complete management setup came to R6254,21. I will keep record of the costs here as well.
Here is some photos of the motor and original auto box after a wash.
