Hi, an update on the progress.
Marius, thanks for the advice. It made stripping much easier. Some advice to all who intend doing this, lots of stripping and patience
Made a 19 mm ring spanner with an open end for the fuel pipes on the pump side. Could not part the brackets holding the pipes together, but pried them apart later as this helps when re installing. The manifold did not want to come loose, so a little help from a rubber mallet and she eventually moved. Replaced the old gasket as this was hard
Some pics before cleaning
- dirty inlet
- cylinder head side
- stripped inlet side
Started to re assemble this afternoon and was very anxious to see if she will start, so I just connected all the components needed to start. Did not need to remove the tapper cover to install fuel pipes, just a little oil, some movement and patience.
Did not connect intercooler, egr or all the covers and brackets.
Replaced the oil pressure sensor. Noticed a small difference here
- old versus new sensor
- oil pressure sensor
Some pics of clean items before assembly
- cleaner manifold
- clean throttle body
Now came the test to see if she will come back to life. primed the filter pump. Turned the ignition and she only cranked over. Did not want to start.
I then remembered that I had not tightened the injector pipes totally.
Did this and purred to life on the first swing.
All be it very noisy due to no egr and intercooler pipes. No leaks.
Very happy and relieved as this is my first diesel engine and lots to learn about them. Idling was normal and throttle responsive. Did not take a test drive.
Now I can continue with the service and connect all the components and covers.
I noticed that the intercooler pipe had been touching the pump pulley and was worn through. Priced this from the agents and at R 1000 rand, I have decided to make an alternative solution. Will see if I can split the pipe and install a stainless steel centre section
