Not being an overly educated fellow, I find it a bit daunting to navigate the site. So, if this is not the correct place for this post, bad luck.
I need a new/ used rear door opening handle, (the one on the outside). The agents don't have and the second hand market seems to be out as well. If anyone knows of a usable example, please let me know.
Thanks,
Toprob
I assume you have a Gen 2 (based on the 2.8 engine you have).
If everything else fails, get it from overseas - it will probably cost less! You can try here: http://myworld.ebay.com/mitzybitz/&_trk ... 1438.l2754
I bought a set of front indicators NEW for the local price of one, delivered at my door! The seller was 4 Rings Spares Ltd 4rings@btconnect.com.
Thanks,
you are correct it is a Gen2, but it seems the Gen 3 etc use the same handle. I'll definitely check out the sites you mention.
Cheers,
Toprob
Cheers,
Toprob
I might have an old one, (is that the white plastic handle?) I will have a look. Where are you??
Thanks, Mooch.
I am in Nelspruit. You can contact me directly or send me your details and the price etc.
Toprob
(toprob@mweb.co.za)
Toprob
(toprob@mweb.co.za)
