JDV
PowerBrake Kit for 2005 Pajero CK
I bought the above kit but unfortunately "lost" my Pajero when is overturned befor eI installed it
Will be getting a 2011 BK DiD soon
Will the PowerBrake kit fit on the BK as well ?
Thanks for assisting
Johan
Re: PowerBrake Kit for 2005 Pajero CK
Just might fit but best to ask Powerbrake themselves. Thy might even be kind enough to do a swop if needed.
Ryperd
Hi guys,
I need to replace the brake pads on my 2001 Gen 3 3.2 LWB, as well as skim the discs.
Worth replacing with Powerbrake kit? :?
Davidvan
Powerbrake AT discs and pads are awesome, highly recommended
andrew.ashton
JDV wrote:I bought the above kit but unfortunately "lost" my Pajero when is overturned before I installed it
Johan
Hi Johan,
Sorry to hear of your loss.
Did you fit these to your 2011BK? or
Did PowerBrake swap them for you?
If neither and they are excess to your requirements and if they will fit 2002 LWB DiD then maybe we can make a plan.
The LWB Gen3 and Gen4 have different brakes - won't fit.
The SWB Gen3 and Gen 4 have the same (AFAIK) and should fit.
2008 Pajero DiDc LWB GLS
I would just check the front discs - I know the calipers on the Gen4 LWB dont allow you to put 16-inch rims on, and I'm sure thats also the case with the Gen4 SWB?
I mention this because I believe the Gen3's can use 16-inch rims.
Karl
andrew.ashton
Based on his profile, the vehicle that JDV bought the parts for (and then subsequently sadly lost) was a Pajero DID GLX 2005.
