My understanding is that the standard breathers extend up to a hollow steel pipe that runs roughly at the level of the top of the wheel arch (or just under it).
Just BTW: On my vehicle (with spacers), the top of the wheel arch is at about 880mm, so that means that water would have to go above the 750mm mark for it to enter the tube (I believe...).
So in my mind, its only really needed when the vehicle exceeds standard wading depth... which would mean water starts flooding into the engine bay (e.g. water temporarily coming over the front of the bonnet).
The current suggestion I have is to extend the tubes into the engine bay. Having them extended to the back worries me, as surely this is the first part the floods (hence the reason for the air intake being at the front of the bonnet, just behind the lip). Would it be wise to extend it to the engine bay?
THEN, if extending to the engine bay, would you cover it somehow to prevent water splashing up into it??
Are there any other locations to extend to? The roof? what about rain water?
Also... isnt the main reason diff breathers will suck in water, because the diff is cooled rapidly (e.g. when entering water). Thus, if the breather are high as they currently are, and your enter the water slowly, you will probably not pull a lot of water into the diffs. (assuming the diffs are cooled and that its a closed system except for the breather, then water is unlikely to 'push' itself down the tubes...??
Maybe I'm just being optimistic - someone that actually knows something sbout diffs needs to comment
