And even if I don't get the box working again we have some pictures...
(Note to self: The trasnfercase/gearbox combination weighs about a half ton...
Adaptor between Transfer and gearbox: Transfer case to be removed first to access bolt inside adapter to remove adapter from gearbox View from other side Torque converter remove - just "wiggle" it out... This is what you find behind Torque converter:
T/c Adapter: Another pic of the adapter:
Notice the gearbox mount is on this: Just saw a SWB Pajero which was in left front accident where this adapter broke under inpact:
Transfer case without adapter: This is the back of the gearbox after transfer case adapter was removed: To be continued en next post...
