Ok, so now I am thinking if I am going to do the ball joints I might as well do the rest...
Tonossons in Claremont quoted me thus for the parts
Lower Ball Joints R175
Pitman Arm R161
Idler Arm R350
Tie Rods Inner R195/set
Tie Rods Outer R177/set
Now you 4e's have done this recently. Any photo's, hints trips, gotchas?
Nah, I did not take photos.SimonB wrote: Now you 4e's have done this recently. Any photo's, hints trips, gotchas?
Although there is not much that can go wrong.
I would
- clean the steering/suspension parts as well as you can (on the vehicle). I hate working on dirty parts
- mark LHS and RHS components with white paint
- take photos from all angles
- measure ball-joint to ball joint distance on the tie rod (to set it close to correct, so that you can drive to the wheel alignment shop without ruining the new Kumhos)
- put Pajero on trestles (chocks behind rear wheels, handbrake on)
- mark the position of the Pitman arm on it's shaft (not critical, but makes centering of steering wheel easier)
- remove wheels
- remove all bits (4lb hammer, ball joint splitting tool etc)
- the Pitman takes a bit of hard moering
- place on floor and take more pics.
- disassemble
- fit new bits, ensuring thread usage is same on both ends of the rod
- set distance as measured previously
- make sure tie rod ends are locked properly
- fit split pins to castle nuts
- re-assemble to Pajero (check manual for torque specs)
- grease idler (if it has a grease nipple)
- have alignment done (make sure they centre the steering wheel)
- enjoy the savings in $$s
- enjoy the 'solid' feel to the steering (if there is still some 'looseness', the steering box needs to be set a bit tighter (another subject)
Hammer = Problem solver
The bigger the problem, the bigger the hammer
Henk Bannink
