Re: Biggest gen 4 tyres
Be carefull here. You cant just up the width as it will also up the wheel height. Remember the "65" or "75" is an aspect of the height. So going wider and leaving all the other figures the same will give you higher sidewalls as well, which will give hassles with clearance and autobox lock-up points.
This is a website that I always use to compare tyres, or tires as they say in USA. :lol:
http://1010tires.com/Tools/Tire-Size-Calculator
CATS wrote:....They are in fact Ford Ranger rims...
No wonder my car refused to wear them ;)
Louis nel
Sal n 265/70/17 op n gen 4 pas sonder n suspensie, indien nie , sal dit dan werk met n tuff dog suspensie
Louis nel wrote:Sal n 265/70/17 op n gen 4 pas sonder n suspensie, indien nie , sal dit dan werk met n tuff dog suspensie
That's size will fit without a suspension upgrade, John G has them on and they look great. Gives you about 13mm lift as well
Louis nel
Thanks, will fit 267/70/17 tyres within 15000 km, have fit stofpad spacers and lifted the car a lot, will do Firestone air suspension at the rear suspension, prior to Kaokoveld trip end of this year.we are doing the Kunene 4x4 trail to Upupa and then Van zyls Pass and rest of Kaoko.
