Gen 3 SWB RH window winder bottom slide wanted
I am looking for a bottom half round slide on the electric window winder(RH) for my Gen3 3.2DiD SWB. The dealers only sell the regulator as a unit.
Any spare laying around??
Re: Gen 3 SWB RH window winder bottom slide wanted
I have parts of n unit thst i got from cats do you have pics of ehat you need ?
I will send pics of ehat I have tonight
Hi Pfgrobler
The problem is I don't have the slide anymore but you will see on the attached photo the position where it fits in the assembly.
Window winder end
Window winder end
Hi PFgrobler
Could you maybe compare the parts that you have with the image on the photo and identify the part I am looking for?
I asume its the plastic bit at the bottom. It seems mine is facing the wrong direction?
But your welcome come check
It seems as if yours is also missing. The part I am missing is the static jockey pulley at the bottom where the cable runs over.
Im havinv trouble with technology today
Hi PF
That is the one missing from mine. thanks I will PM you with further arrangements. :D
