cawleydavid
Re: Upper & Lower Control arm bushes
Wondering if someone can recommend the best (not necessarily most expensive) bushes for upper & lower control arms. I live in the middle east and can only get hold of Mitsubishi Parts here (the whole kit!!!). I plan to change the whole lot - seems to be cheaper to get them Mail Order (either from Oz or Za). Obviously refurbishing my current ones is not an option, please help!
David
cawleydavid
Found a cheaper solution (Than powerflex.co.uk) a company called Milneroffroad.com also based in the UK supply a complete set of polyurethane bushes for 160GBP
Still waiting for advice on raising the suspension a little - do I just need springs & shocks or do i need to make additional adjustments anywhere else on the car to compensate for adddional inch or so of lift?
Morrisn12345
am still new into this forum but i drive a Mitsubishi pajero and i noticed that the two wheels at the back are finishing one side and went to mechanic to tell me but not surely that is the problem of upper or lower control arm bushes. i live in phalaborwa and where i can find this parts for my vehicle, please can you help and advice?
regards
Morris
cawleydavid wrote:Found a cheaper solution (Than powerflex.co.uk) a company called Milneroffroad.com also based in the UK supply a complete set of polyurethane bushes for 160GBP
You can lift the Pajero for 40mm using only 20mm spring spacers.
I did it in mine 3 years ago on the stock suspension and have no problems till now.
Re: RE: Re: Upper & Lower Control arm bushes
Morrisn12345 wrote:Hi
regards
Morris
First take you car for wheel alignment. Ask them to test play of the different joints. You will clearly see if you have play. For parts check the beginning of this topic.
regards
Morris
