Hello Members
i have a 2001 3.2 DiD Pajero and need to replace the passenger side headlight unit, does anyone please have step by step instructions on how to do this?
regards
Mark
Mark
Easy as pie. I will try and do this from memory:
You need to remove the center grill part first.
Then there are 3 bolts that needs to be undone that hopd the headlight, nr10 spanner I think.
Then there is one nut hidden away behind the plastic splashguard inside the wheel arch behind the light. This one is also nr 10 spanner but difficult to get too unless you unclip a few of the clips inside the wheelarch.
The headlight should now be loose.
Why dont you download the workshop manual on the POCSA website. There are some nice blown up pics in there that will assist greatly.
