Hi all. I am new to this forum. I have a generation 1 swb v6 3litre I bought just recently. Everything on her works well. But however I have no overdrive. Overdrive light comes on when pressed the OD OFF light but nothing happens which tells me it won't go into overdrive and it only goes higher than 3rd gear. I really need advice on this. The gears shift smothly otherwise with no problems. I was told to look for the overdrive solenoid that may be faulty but I can't find it. The wires coming from the switch on the lever go to a plug under the centre console then disappear under the carpets. Has anyone got any tips???????
Also what fan belt would this engine take. It is the 6g72 v6 cyclone 3litre engine. My contact number is +260 950669289
