Andre L
Vacuum pipe route
Please help. Can somebody assist me by explaining the route of the vacuum pipes connected to manual gearbox. Where does the vacuum come from ? Route to operate the locks on the rear diff and 4x4 box and super select.At which point does it connects to the vacuum supply. My vacuum pipe to engine compartment is missing.
Thank you
Andre
Andre L
vacuum pipe route
I asked for information on vacuum pipe route and forgot to mention the model. It is for Pajero 3.2 did 2001 manual.
Andre
Re: Vacuum pipe route
Dit is presies wat ek ook wil weet . Ek weet dit begin by die oordrag ratkas en loop tot voor by die vacuum solenoid onder die "airbox" en dan van daar na die vacuum tank wat dan die "freewhweel clutch " werk. My kar se pyp is erens tussen die ratkas en die solenoid af maar waar , dit is die vraag. die probleem is dat daar nie genoeg spasie is om te kan sien wat aangaan nie.
Not 100% an answer to your question, but this may help.
http://4wd.blogeasy.com/article.view.ru ... eID=318776
