ZIMBO
New Member ZIMBO
I have just bought a Pajero, supposedly 1997, with a 2800 Intercooled turbo engine, with automatic gearbox. It seems to be in good condition, pretty original with no obvious modifications, and shows 85,000kms on the clock. I have done about 1,000 kms in her since purchase, and she hums along pretty well.
My previous experiences with 4x4 vehicles was all series Landrovers, so this is a whole new ball game for me. I am also more of a petrol fan, but there is a first time for everything. I was very pleased to find and join this club, and I assure you I have lots of questions!
I am a Textile Manager , but have always done a lot of mechanical fiddling on my vehicles, so know my way around a toolbox. The Pajero will be used mainly for holidays at Kariba and Chirundu, and will tow a fairly heavy eighteen foot boat.
I look forward to picking everyones brains and ensuring I use my vehicle correctly and get the most out of her.
Re: New Member ZIMBO
Welcome to the forum, and congratulations on an excellent SUV!
The kms sound low, so you might just have bought a bargain.
The critical items on a diesel engine are oil cahnges, cooling system and EGT (exhaust gas temperatures).
Oil Changes:
Stick to 5000 intervals with the best oil you can find (15W40).
  • Caltex Delo400
  • Shell Rimula Diesel
  • Shell Helix Diesel
change the oil filter with each oil change. Here in SA they are cheaper from the agents than 3rd party!
Cooling:
Since you don't know the history of the maintenance, I suggest the following:
  • full set of hoses (including heater hoses). Keep the 'old' ones as spares in the vehicle.
  • Mitsu thermostat
  • cooling system flush
  • best coolant you can find. I believe in Caltex Extended Life Coolant.
EGTs:
Keep the EGTs down by
  • having the injector pump calibrated
  • keep the revs down to 3500 max
  • shift up early (±2500)
  • don't depress the pedal if it does not result in higher rpm - it just over-fuels the engine and causes high EGT
  • have an EGT guage fitted (all TD engines should have them)
Enjoy!
Fielies
Welcome Mr.
