gomi
Idler arm bushing
Hello there,
I own a Gen1 paj.
I have a problem with the bushings on the idler arm (steerting), this bushings are defective and I need to reaplce them, until now I have not found it at all, in any shop. but they asked me if it is compatible with another generation. is it?? other wise I will have to make it my own but also found a problem, the lower nut located on the screw shaft it is so tight, I don't know it is is locked or I just need to use an extender to my wrench to use more force to release it. I am atttaching a pic of the idler arm and pointing at the nut.
thank you.
Israel
Re: Idler arm bushing
If I'm not mistaken, that nut gets tightened to 140NM so it is pretty tight on there. Spray it a few times with penetrating oil and let it sit overnight. Apply a blowtorch to get it hot and remove it.
Use a good wrench or socket. The last thing you want is round the nut.
The last alternative is to cut a small side cut with a dremmel in the nut so you can pry the cut open and then easily remove the nut.
I replaced my idler arm with that of the Gen2.
It is a straight bolt-0n, and it is a stronger design.
