Complements,
You mentioned it would be cheaper if you tackeled it differently; how would you have done it differant if you have to do-over?
Trying to find where I said it would be cheaperJDV wrote:Hi SimonB,
Complements,very nice looking and explenation
I don't think it will affect the overall strength very much, as long as the sides are properly braced.First off, because I would like to make my drawer deeper for the same height, do you think I could replace the front (door side) bottom alu 25mm square tube cross bar (of the frame) with a 30mm flat bar? This would allow me +-20mm more for my drawer depth but do you think it would deminish the overall strength of the frame unacceptably? Maybe if I put in a few flat bar braces on the sides of the frame?
I haven't but it is something I would like to do. I saw an elegant solution on Kevin's (on this forum) Pajero where they modified a Prado cargo barrier. Not sure how the bottom was fixed but the top was fixed with a bracket bolted down behind the rear seat belt mounting. (Hmmm I've now had another idea... let me get back to you on thatSecondly, did you ever consider fitting a cargo barrier to stop goods flying to the front on heavy braking or do you strap everything down? If one would like to fit a cargo barrier how would you secure it without drilling holes?
the one thing I didn't think clearly through is the electrics, and something else I want to change is somewhere to permanently mount my compressor.Not trying to quiz you but you seem to have thought through your design very well and may very well have considered these aspects and discarded them as impractical.![]()
