Greg,
Why so quiet....? What is happening on the new Pajero front?
Hi Greg,
I have upgraded from a Gen3 SWB(Petrol)to a Gen4 SWB(Diesel). I prefer the SWB due to my personal situation. The Gen 4 SWB can accommodate 16" rims but the LWB can not as they have larger diameter front brake discs. On the new SWB models you get the exceed model which have the "wood trim" on the steering/dash and door panels while the normal GLS have black leather and plastic as trimmings. Please note that this is not the rule as sometimes you find a normal GLS with the same trimmings. If you shop around you will probably be able to find a vehicle that have all the correct trimming as "OE" As mentioned, all Gen 4 have the Common Rail engines and can use 500ppm diesel.
