Is this the lift you did? I saw there are lots of little pipes going from the body to the subframe - were the pipes long enough for you to do the lift? Also, is the radiator attached to the body or the subframe?cloyd wrote:4E,
Yes, four bolts. The lift that you can get is totally dependant on the length of the new bolts. The standard ones are 140mm long. So, if you can get 180mm bolts, you can lift the rear end by 40mm, etc.
The lift is basically moving the whole body upwards by eg 40mm away from the rear suspension subframe. Unfortunately the ground clearance below the subframe and suspension parts stays the same but the body is moved upwards by the amount of lift thus giving a greater break-over angle and better departure angle.
Cloyd
Regarding the spacer lift being considered for the group buy, we might have to change the thread topic to Gen3 and Gen4 group buy if all goes well
