HI Roelf - Silly question....RoelfleRoux wrote:I'll do my best to ellaborate on the symptom.
1) Suspension is quiet and perfect over uneven surfaces - where I would normally expect the anti-sway bar bushes to complain.
2) The noise is "solid" and can be felt under my feet.
3) It seems to only come out on big extention of the spring/shock. That is why (I think) it only manifests itself on uphill and not down hill.
Sent from my GT-I9305
Have you checked if your battery is fastened down 100%? it is situated above the left wheel and could cause the clunk when you drive over the speed bump at speed?
I know mine is loose, the appie who fastened it (at the diesel mechanic workshop) over tightened the top strap nuts and tore the steel eye mounts out from the plastic fibre battery tray....
Need to see if i can find a secondhand one or mod the tray to be more sturdy.
