Oom 4E4ePajero wrote:Christo,
IMHO, whatever caused the Snoop to destroy the original head has not been fixed!
The result(s) of some problem was fixed, but if you don't get to the bottom of this, the cycle WILL repeat itself.
It is time for a thorough cooling system check:Don't use it until this is resolved.
- Radiator
- Radiator cap
- Cowling
- Viscous clutch
- Thermostat
- Water pump
- Coolant (I recommend Caltex Extended Life)
That is the thing. Waterpump, radiator, radiator cap, thermostat was all replaced with engine rebuild, which by the way was not due to overheating as I never had overheating issues before the engine rebuilt. All waterpipes etc was also replaced a while ago as preventetave maintenance. So all that was not yet replaced is the viscous. I am happy to change that to new original, even if it does not resolve issue as it has done 300000kms, so might need new goo in any case. Only thing is that before rebuilt viscous did not give issues so why now after rebuild?
I see the bottom cowling around the viscous is missing, not sure it was missing before rebuild as it never gave heat problems so I never checked. Also the sponges around the radiator is all gone where there definitely were some before. Maybe that is the main thing.
