I have been using a workaround to stop my fridge slide from exiting out the back window on the slide on my packing system and think it is time to make the permanent solution, Simon B used one of these and I am looking for simlar please can you assist or advise on what you used, I need to secure the slide properly before I lose it out the window 1 day....
I have seen some with a spring in the mechanism does anyone know where to get these too, as seen on some of the commercial products, like hens teeth it appears
Thanks a mil
David
David,
If you have a Conqueror agent close to you you would find one of those spring loaded thingy-ma-jigs from them as all the doors and fridge sliders in the trailers and caravans use them.
Thanks a mil, there is one that opened up just a few km's away in Midrand, at last I can get my thingymajig for my slide.
Much appreciated!
Much appreciated!
Thanks I have ordered these from conqueror, will definately do the trick. Much appreciated
Conqueror didn't have stock and took long to organise these, they did refer me to Acorn Fasteners in Centurion, and I got these items (same as conquerors) from them for R72 each. They have alot funny screws and stuff too, so a good place to know for the DIY'er.
http://www.acornfasteners.co.za/ContactUs.asp
David
David
