Hi G
No I have 265/75/16 on. At the back I have (will just check again) 925mm
Ah, I see...
I measured mine from the centre of the rim (middle of the centre cap) to the wheel arch - that way the tire size and rim size don't influence the measurement - just the suspension.
2008 Pajero DiDc LWB GLS
Andre,
Any chance you took the Inner diameter and outer diameter measurements of your rear spacers and have some more detail on the front spacers. I am considering adding a 20mm front spacer (believed to result in 40mm lift) and a 15-20mm rear spacer (believed to result in 45-60mm lift), Please could you share some more details on your mod.
Thanks a mil
David
Thanks a mil
David
Hi GJM,
I have been in contact with Andre via email, he will be sending some more pics and details of his mod when he is back at the office, I will add to the van zyls springs and new shocks thread, which I am hoping to finish off in around 2 weeks on a cheap, simple and viable solution.
David
David
