Re: Oil changes
AndreBenson
Re: Oil changes
Nope Manual.
Re: Oil changes
This is what I have on Autodata - don't take it as fact as I have found errors on the program before.
AndreBenson
Re: Oil changes
So all the oil in the diffs and gearbox where drained and filled, apart form the transfer case(idiot before completely screwed up the fill bolt).
The crap that came out of these where really bad!! Thank goodness for that little magnet on the bolt!!!
Now I have a new problem. I have a heavier gear change than before and my third gear scratches. what could this be be??
I have no leaks that I can notice or see.
Re: Oil changes
What oil exactly did you put into the gearbox?
Gerrit Loubser Image
AndreBenson
Re: Oil changes
Hi Gerrit
Castrol 75W/90
Re: Oil changes
You could perhaps try Caltex Easyshift, which is well known to improve shift quality, or Castrol BOT 130 M, which is a synthetic. When I changed the Patrol's gearbox oil to BOT 130 M, I experienced an improvement in shift quality that was almost miraculous.
AndreBenson
Re: Oil changes
Hi Gerrit
Would this work in the transfer case as well??
I'm getting a new bolt next week and am going to drain it too.
Re: Oil changes
No, the gearbox oil is a GL-4 oil, while the transfer box uses the same GL-5 oil as the axles, if I remember correctly.
