AndreBenson
Re: need height
Hi G
No I have 265/75/16 on. At the back I have (will just check again) 925mm
Re: need height
Ah, I see...
I measured mine from the centre of the rim (middle of the centre cap) to the wheel arch - that way the tire size and rim size don't influence the measurement - just the suspension.
2008 Pajero DiDc LWB GLS
Davidvan
Re: need height
Andre,
Any chance you took the Inner diameter and outer diameter measurements of your rear spacers and have some more detail on the front spacers. I am considering adding a 20mm front spacer (believed to result in 40mm lift) and a 15-20mm rear spacer (believed to result in 45-60mm lift), Please could you share some more details on your mod.
Thanks a mil
David
GertM
Re: need height
Looks like this thread has died a peaceful death....RIP
Davidvan
Re: need height
Hi GJM,
I have been in contact with Andre via email, he will be sending some more pics and details of his mod when he is back at the office, I will add to the van zyls springs and new shocks thread, which I am hoping to finish off in around 2 weeks on a cheap, simple and viable solution.
David
